Photo A2. Crop feature does not copy to all loaded images
I create HDR images from 3 shots more often than not . When I load Fujifilm RAW files into Photo AI2 and crop the highlighted image and then adjust it for noise, sharpening etc. and then copy settings to all the crop does not copy to the other images. To merge HDR images it is essential that all source pictures have the same dimensions and position. This failure to copy crops renders both the crop tool and upscale tool useless.
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Blockquote
Thanks for reaching out. This is expected behavior at the moment since images are expected to have different data so applying the crop to other images seemed unsafe.
We will be improving the Apply Settings to All feature soon to include options for crop and other adjustments.
