I have just watched a video showing the use of the guided upright tool in Lightroom … It would be lovely to have something similar in TS … something that gives a lot more control than is currently offered with the lens correct and crop tools. A hopeful wish.
Personally I wouldn’t spend another $80 on something every RAW converter should have anyway. But I agree that a KeyStone correction with guidelines to make a square, for example Horizontal & Vertical, where the 4 corners are used to adjust the perspective would be a great addition to the Lens Correction in Studio.
Note though that it can be achieved manually using Tilt & Pan by turning off the automatic lens corrections.
