PCM audio with mxf container failing on only some models
I get an error when attempting to run models locally on DNxHR videos containing 24 bit PCM audio (mxf container). Strangely the Starlight models (mini and precise 2.5) handle the files without issue, but other models (Artemis, Iris, Stabilization, Denoise) do not. The issue appears with files produced via DaVinci Resolve or even Topaz Video (v1.5.0) itself.
Can you share the logs?
To gather logs, please open the app and select Help > Logging > Get Logs for Support and attach the zip file to your reply.
logsForSupport.zip (18.8 MB)
Could you please also upload one of the problematic files for testing?
Submit File to Dropbox
