PC build recommendations for 2026
Cool! I also have a mid tower case. And yes that is how all my mac pro’s work but i have changed it this time because your pci slot fans gave me an idea.
I have send back the TG case with glass and ordered the mesh side panel version. Which can put 2 140mm fans straight above my plx card and 5070ti and suck all the warm air out and blow it through the mesh. Only the 2 front fans push air in. If my thermal idea is correct that is how you pull every hot air away including the heat pockets at certain spots. But i could be wrong!
Haven’t installed the 5070ti and the mesh fans though because i just got it running and did first cinebench test to watch MOS temps for my case fans bios setup.
That’s great information and I actually am very familiar with OWC as I’m primarily a Mac user and I’ve used pretty much nothing but OWC RAM in my upgradeable Macs for many, many years and only had 1 RAM issue, which they very promptly and kindly resolved. I’ve never had a problem with their customer service, and in fact, I’d go so far as to argue the complete opposite of that one reviewer and say that they have really never failed to wow me. So, I guess mileage will vary but I can personally attest to the quality of not only their RAM, but of a lot of their other products, which have always been very top-notch.
Yes, it’s a good company, honestly. I actually forgot to mention that they even upgraded my ECC DDR5 RAM during the RMA/warranty process. So yeah — I definitely undersold how happy I was. I’m actually extremely happy with them.
Any recommendations for SLP model, any changes suggested appreciated. Here is the build which is in the process of building before shipping:
  • Graphics Card: NVIDIA GeForce RTX 5090
  • Processor: AMD Ryzen 9 9950X3D
  • Processor Cooling: MAINGEAR Epic 360 RGB
  • Fans: Stock RGB Fans
  • Motherboard: MSI Pro X870E-P WiFi
  • Memory: 64GB RGB DDR5NVMe
  • SSD (Operating System): 4TB XPG Mars 980 Pro
  • Operating System: Microsoft Windows 11 Home
  • Power Supply: 1250W MSI MAG A1250GL
  • Power Supply Cables: Stock Cables
  • Warranty: Included 1-year Warranty
  • Any RTX 5090 bought before it becomes a collector’s item makes sense in this GPU apocalypse. Just try to avoid paying outrageous prices.
  • I love XPG hard drives, but don’t underestimate the SN8100.
  • If gaming is completely off the table, I’d definitely go with the 9950X. More thermal headroom means higher sustained clocks, potentially lower I/O die temperatures, better Infinity Fabric overclocking potential, and ultimately higher memory bandwidth.
  • Conidering your budget foget air cooling and go for a CPU watercooling.
  • If you can find this modules, run for it, they are rolling thunder
Thank you.
Forgot two last points
MSI MEG X870E UNIFY-X MAX as the motherboard. Its has an unsynched BCLK generator which can be a game changer
And last but most important of everything considering its price : preserve your 12VHPWR/12V2x6
It will melt a day or another due to bad conception, moreover on long load. So I suggest WireView Pro II GPU
