Pause/resume threw away 17 hours of rendered footage
Great, thanks for the links!
Given I’m currently on 5.5.0, anyone know if I’ll lose anything by downgrading to 5.3.6? (I guess I can just try and see…)
No, ok you’re saved presets I don’t know. What I personally do at the moment is to have two versions installed at the same time, V5.3.6 and always the very latest, but I only use the latest version for model RheaXL.
I tried also RheaXL but some things look very terrible…
  • When faces are slowly zommed in coming out of blur.(Alien faces[not looking natural])
  • The faces overall look mostly like having a plastic like surface.(unusable)
  • When it´s raining moving objects are smearing on their way very noticable
What RheaXL is doing very best are all things that don´t have faces and all scenes without rain.
I prefer Rhea1 at the moment.
HDR isn´t also that good…i have to modify a lot of the settings into extreme to get something usable out where nothing is missing because the images are too dark…After exporting i have to use another tool to correct the colors and the brightness gradient… - I am thinking about using another AI not from Topaz to do HDR instead.
I discarded all i have done with RheaXL & HDR and i am doing them now with V5.3.6 again.
Version 5.3.6 is the last Version that i can work with(also with a lot of bugs but mostly usable).
yes I know it’s very problematic, but it can be used for certain scenes and then it delivers a wealth of detail like no other model, or what sometimes do is two encodes Iris + RehaXL and overlay it in video editing software, set opacity both merges into one, then often you can’t see face disorientation.
Here is a testsample 100% RheaXL made 4k Yoyager Testsample (qtgmc-splineresize-Rxl1-Ahq12-Thd3 and more).zip (24.4 MB)
18 of February and the pause button is still broken!
Unbelievable… And to think I paid to renew my licence for mainly this feature.
I could imagine that Topaz is close about bringing back a fully fuctional Pause/Resume function in one of the next releases…
