When enlarging a photo using cropping if you utilise Photo AI the resolution is exaggerated.
Can you upload a few screenshots of what you mean by this? Try to include the original and the processed version so I can see the difference.
Also, I’m not exactly sure by what you mean when you say the resolution is exaggerated. You can control the default resolution in the Preferences > Autopilot > Upscale and Resize settings.
