Output Random Render Glitch
  1. Lower left corner of video renders random frames as a rectangle of under-processed pixels.
  2. iMac Pro Mac OS 13.4.1 (c) (22F770820d)
logsForSupport.zip (111.5 KB)
4.
This looks like a glitch that the devs are aware of and are working on a patch in conjunction with Apple. If you can try updating to Mac OS 14.3 as some users have found that fixes it. If not then open a support ticket with the team and send the full logs.
Thanks for the update. I found that by using shorter sections of the file the glitch went away.
Bruce
