At the end of installation of version 5.3.6, there is again an out-of-screen panel displayed out at top left position.
The workaround is to change the display resolution to bring back this faulty panel in the displaying area.
Are you on a Mac or PC system?
If you can send the logs, so we can take a look at what resolution the app is trying to open in on your system and what resolution you have your screen set to.
Thanks.
Hi Kyle,
I am on a Windows 10 PC with FHD resolution 1920 × 1080 pixels.
I shall send to you the log asap.
Kind regards.
Vincent.
Envoyé à partir de Outlook pour Android
Hi Kyle,
Sorry for the delay.
Please, find attached the logs you requested.
As usual, feel free to ask me more explanations.
Kind regards.
Vincent.
logsForSupport.zip (641 KB)
In the logs it is showing the app is set to open at coordinates 0,0 in a resolution of 1920x1040 which is smaller than you screen is set to.
It is odd that it is opening slightly off screen. Ill send a message to the team about this as we dealt with this before in a previous version.
Hi Kyle,
Thanks
And yes, it’s a recurring bug!
Best wishes.
Vincent.
