Out of hard drive and incompatible input error
Having error kindly find the attachment
logsForSupport.zip (8.4 MB)
in some videos
Seeing an error that your hard drive has run out of storage space. You will need to clear some space out for the export to have enough storage to export.
Also seeing an error related to missing colorspace metadata.
I recommend converting your input using Handbrake and then try importing the converted version back into the app for processing.
Here are the steps to convert it in the handbrake app:
  1. Drag and drop your video to import it
  2. I recommend going to the “dimensions” tab and under “resolution limit” > none
  3. I also recommend going to the “video” tab and under “framerate (FPS)” > Same as source
  4. Then click “start”
This will ensure that it retains the original resolution and frame rate with the converted file.
