Out of focus enhancement
Hi there,
I am new to topaz ai (just purchased Blackfriday 3 pack), and have few questions:
  1. I have a video footage with out of focus person ( the focus point is slightly behind him), that i’m trying to correct, but no success so far. Is there an option to do it?
  2. While i tried using Iris enhancement, and another model my CPU and GPU never crossed a 50% usage mark when checking task manager. Also the RAM utilization was low less than 16GB I tried choosing different settings for rendering. Why is that?
My PC specs that i bought specifically for rendering:
CPU: Intel 285K
GPU: Gigabyte RTX 4090 Windforce V2 24GB
RAM: 32GB DDR5 7200mhz
SSD: Gen5 14,500MB/s
Motherboard: MSI Z890 Tomahawk Wifi
Thanx in advance.
That’s just how TVAI runs. It’s using things that don’t always get reported in Task Manager—but also if you run more than one instance of TVAI, the net-speed is faster. (So if you get 50 FPS with one instance, running two might get you 30 FPS each, making the total speed 60 FPS.)
With the Iris models, turning up the sharpen slider will increase the face enhancement. I think Rhea works the same. You’ll need to click the ‘Enable Parameters’ button to get to the sliders.
