Order of Operations
Does Topaz recommend an order of operations?
If bringing a Resolve project to Topaz to de-interlace and super scale should one do this before or after things like colour correction?
Thanks.
John
Topaz support claims the order could be either way, but best practice to Topaz it as the last step in the workflow.
TVAI has a color alteration bug that may invalidate color grading done in DaVinci Resolve.
Also, if you are working with HDR material, you should not use TVAI because it does not support HDR.
