Option to Post-Process with Another Program/Script
Could we please have the option to specify a tool/script which will run on the output file once it’s saved? This would help me as on every saved image I run a small utility to rename the output and make sure the “finished” JPG has the correct metadata.
In terms of operation you just need to provide the ability to select an executable, and then when save is complete run that with the output filename as parameter.
I previously raised this idea and it seemed to be welcomed, but nothing has happened since: [Add Option to Post-Process with Another Program/Script]
Could we please get this formally adopted?
Thanks
Andrew
Don’t forget to vote for your ideas @andrew3-7835
