Opening an image with TG aborts a running process
If an image is currently being processed and you open another image with Topaz Gigapixel (via the context menu: Open with), processing of the first image is canceled and processing of the new image begins.
This should not work like this. If an image is being processed and another image is opened with Topaz Gigapixel during this process (via open with), the second image should be queued for processing and only processed when the first image is ready.
It sounds like you’re confusing the app here.
If you already have Gigapixel open, you shouldn’t try and call Gigapixel to open again if it’s already open and working on something.
Instead, you should go ahead and open the images you already want to work on in one session to batch process them at once.
