Hi, Just deleted all my photo software except for On1 and Topaz to try and get to grips with both rather than jump from one to other of the many others I have, when I send an image from On1 to example Topaz GigaPixel it sends it back to On1 with the same prefix/file number it was sent with yet Gigapixel states the sufix would be -gigapixel, yes it shows as a Tiff file on return. Is this correct? Thankyou, Russ.
I too use On1 as my main photo editor and Topaz Sharpen and DeNoise as and when needed.
If you send to Topaz from On1, it will make a copy (either TIF or JPG) and work on that. When it is sent back to On1 it retains the same name : ****.copy.tif/jpg.
The suffix is applied only if you use the Topaz product in standalone mode. Otherwise, you have to rename the file yourself.
TY, Russ.
