On Demand process photo. Manual process options
Option to auto process or manual process upon selecting the photo enhancement. To prevent the software from working on the photo before you finalize the enhancement choices.
You can go to Preferences > Autopilot and either enable or disable the option to Automatically apply filters. If you disable this option you can then import images and have the option to either add your own adjustments or Apply Autopilot.
