Olympus E-M10mkII load image failes
Photo AI 3.2.2
Drag from folder to Photo AI’s display.
Images load fail.
Steps to reproduce issue:
  1. Step 1
    open Photo AI
  2. Step 2
    drag folder (some raw image files. “ORF”)
  3. Step 3
    Failed images.
    2024-09-29-23-59-35.tzlog (79.4 KB)
system profile Sended
Thanks for sending in that information.
I would like for you to try updating the GPU driver to ensure that you are using the latest updated driver for your card. You can do this by following the steps below:
  • Open your Device Manager
  • Go to Display adapters and double-click on your GPU. Then go to the Driver tab and Update the driver.
Thank you.
I updated Display Driver, but load images failed.
I wonder if any other users have been involved in the same problem.
Let’s try adjusting your AI Processor by going to Preferences > General and setting the AI Processor to CPU then clicking Apply.
Thank you.
Completed Image files
