Hi,
I have discovered a class of image for which Photo AI creates an odd processing artefact. The upscaled and sharpened image below has an odd “halo” around the planes’ bodies. This isn’t apparent in the original (top image). It could be that there’s a bit of chromatic aberration in the original and Photo AI is turning it into a separate image element. Unfortunately I only have JPEGs of the images, so I can’t go back and correct the CA at source.
This is all with default settings in Photo AI.
Is there anything I can do to stop this effect? If not, can you try and address it in a future release?
Thanks
Please check this week’s release, it should have it fixed.
