Nyx Recovery Detail bug
Does Nyx support “Recover Detail” function? When I type 30 and enter, it just refuse to accept command and shows 0. Please check. One more thing, tool tips are strange, when I click, it shows tooltip and stay there. How can I hide tooltip? Please check also. Thanks.
To be totally clear: The slider works as intended, but manually entering a value does not work.
The ‘Sharpen’ slider is missing entirely.
Manually changing the Sharpen (blur) value in the CLI does change the output. And using Auto and Relative to Auto do change the value of Sharpen, but the user is not able to interfere like the other values.
The custom values bug should be fixed in the 4.0.1 update:
