Nyx message is missing when "Enable Previous Model Versions" is enabled
When the “Enable Previous Model Versions” setting is enabled, the warning message with Nyx letting you know that it only supports 1x scaling disappears.
Missing message with Previous Model Versions enabled:
Example of message that is supposed to be there:
Thanks for reporting this! Will be fixed very soon.
