Not working with mixed resolutions
If I import a 2k and a 4k clip, and export with default setting of 2x upscale, it will export both clips to the same output resolution. This means you can’t batch process clips unless they are all the same resolution. Really annoying.
Mac Studio, latest topaz version, using the iris model.
