idk if its a bug or not but i cant export my videos. it was just working like 5 minutes ago
Could I take a look at the app’s log files to see what is causing the error in Video AI?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport.tar.gz” file to your reply.
