Not in a conventional Window/normal Window, very, very annoying
Why on earth is the program not in a conventional window? Very annoying to not have the normal window controls and behaviour. Particularly when you have managed to put the latest versions of Gigapixel AI, DeNoise AI and Sharpen AI in normal windows.
I’m using Windows 10, version 22h2, build 19045.3930
What’s not normal about the window?
Clicking the top of the window and dragging to the top of the screen does not maximise the window. When maximised, clicking the top of the window and dragging does not return the window to its previous size. For me, using two screens and frequently moving windows back and forth, that is a real pain. There is another post on here about the windows shortcut keys not working as expected either, I don’t use them myself, but I imagine it is frustrating for those that do. I’ll try it on a Windows 11 machine tomorrow to see if the windows snap behaviour works as it should, I’m not very optimistic though.
I have TVAI on a Windows 10 system and a Windows 11 system. The windows operate normally on both.
Odd. Now using it on a Windows 11 machine, and it acts as I expect a Windows app to behave :slight_smile:
