Not happy
I am not happy with the latest upgraded filter. It is too strong , distorting the image.
I think you have gone overboardwith the noise reduction and sharpening, it is distorting the images.
Don’t make multiple threads about the same subject, just update your original thread.
I have learned that for the very BEST results that will be PRINTED it is best to use BOTH Topaz Photo AI AND your photo editor in conjunction to tweak the final digital image before printing. Topaz alone may not always give you the final image quality you want when it comes to a large framed print. Also experimenting with .TIFF and .DNG files is critical as they both produce much different results when looking at a blown up printed image.
