Noise & Sharpening together
Hello all,
I have several images where I want to apply noise and sharpening. But in the menu for the automatic mode must be preferred, between noise and sharpening. Why is there no option to enable sharpening and noise together for all images?
The automatic mode is great, but I want to decide what to do with the images. I have a lot of images that need to be processed automatically and I miss this option.
That settings only applies when there are low amounts of both. We find that when both remove noise and sharpen models are turned on, there’s a higher likelihood of artifacts being created. You can select “correct the prevailing issues” to get the best of both worlds.
