(Repost from Topaz 1.6 thread)
Topaz removed the ability to export rawvideo format to pipeline?
ffmpeg.exe [options] | “C:\Program Files\Topaz Labs LLC\Topaz Video\ffmpeg.exe” -report -hide_banner -i pipe: -filter_threads 1 -vf “tvai_up=model=prob-4:scale=0:preblur=0:noise=-0.9:details=0:halo=0:blur=0.25:compression=0:estimate=8:blend=0.2:device=-1:vram=1:instances=1” “-c:v” “rawvideo” “-f” “nut” - | ffmpeg.exe [options]
it gives me an error:
Input #0, nut, from ‘pipe:’:
Metadata:
software: Lavf62.13.100
encoder: Lavf62.13.100
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Video: rawvideo (RGB0 / 0x30424752), rgb48le, 1920x1080, SAR 1:1 DAR 16:9, 29.97 tbr, 60k tbn
Metadata:
encoder: Lavc62.29.100 rawvideo
Stream mapping:
Stream #0:0 → #0:0 (rawvideo (native) → rawvideo (native))
[in#0 @ 0000021e25aba0c0] Error opening input: Invalid data found when processing input
Error opening input file pipe:.
Error opening input files: Invalid data found when processing input
[vost#0:0/rawvideo @ 0000016c9f1ddf80] Error submitting a packet to the muxer: Broken pipe
Last message repeated 1 times
[out#0/nut @ 0000016c9f14c500] Error muxing a packet
[out#0/nut @ 0000016c9f14c500] Task finished with error code: -32 (Broken pipe)
[out#0/nut @ 0000016c9f14c500] Terminating thread with return code -32 (Broken pipe)
[out#0/nut @ 0000016c9f14c500] Error writing trailer: Broken pipe
[out#0/nut @ 0000016c9f14c500] Error closing file: Broken pipe
[out#0/nut @ 0000016c9f14c500] video: 36450KiB audio: 0KiB subtitle: 0KiB other streams: 0KiB global headers: 0KiB muxing overhead: unknown
frame= 3 fps=0.5 q=-0.0 Lsize= 24300KiB time=00:00:00.36 bitrate=542371.7kbits/s speed=0.0599x elapsed=0:00:06.12
Conversion failed!
If I replace:
“-c:v” “rawvideo”
with
“-c:v” “ffv1”
it works.
[ffv1 @ 00000181EEB3B500] high bits_per_raw_sample, forcing range coder
Output #0, nut, to ‘pipe:’:
Metadata:
software : Lavf62.13.100
encoder : Lavf62.13.100
Stream #0:0: Video: ffv1 (FFV1 / 0x31564646), rgb48le(pc, gbr/unknown/unknown, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 29.97 fps, 60k tbn
Metadata:
encoder : Lavc62.29.100 ffv1
But it makes no sense to compress the data in a pipeline.
