No more able to use Topaz AI Denoise
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
1: import picture
2: analysing image
3: denoise
after ‘‘denoising’’ … the result is horrible. May be I am doing something wrong…? … the problem started after updating to v3.2.2 Windows 10
screenshot
  • List item
We’ve had a few reports of this being a problem with recent updates, and it is usually associated with the system needing to meet the Minimum System Requirements or associated with the GPU driver. I suspect that your machine is more well-equipped than your father’s computer, judging by the screenshots you sent to us to review.
To investigate this problem better, we’ll need to examine your full system profile information. This will help us understand what might be causing this issue.
I would also like for you to try updating the GPU driver to ensure that you are on the latest updated driver for your card. You can do this by following the steps below:
  • Open your Device Manager
  • Go to Display adapters and double-click on your GPU. Then go to the Driver tab and Update the driver.
Hi… is there a ‘’ simple’’ way to ‘‘go back’’ and undo the last update ? Before that it was working ok
You can find all previous installers at the following link:
