- No audio, neither playback, preview or export.
- MacBook Pro, M3 Max, MacOs Sonoma 14.6.1
There will not be any audio in the app when previewing or playing the videos, as that is not a feature at this time.
When you export out the video the original audio file should be included unless you set the Audio Mode in the Preview and Export Settings Panel to None.
Can you share your logs here or with the support team directly for review? help@topazlabs.com
First, thanks for answering , but:
a)
“There will not be any audio in the app when previewing or playing the videos, as that is not a feature at this time.”…
this can’t be a “special” feature … it’s a must. … it’s 2024 not 80ties… can’t believe it.
b)
Prieviews don’t have any sound… allthough settings as commanded
see attached pictures of two test files
please solve this issues.
The dev team is looking into adding audio playback in the future as it has been requested as a feature, however it has not been implemented yet.
The screenshots show that you are still running a Preview which would not have any audio as the file has not been exported out of the app to have the audio file reattached to it. When playing in the app or running previews there will not be audio at this time. Only once you export the clip will the audio be included with the file again.
Mac Studio.spx (9.3 MB)
Having same issues. Sound is good before processing and I understand about the no audio during processing but again, there is no sound in the processed file.
Can you share your logs from the processes that you had issues with the audio file? You can share them here or send them directly to the support team at helpp@topazlabs.com and make a mention of this forum post.
