No access to Camera-Specific colour profiles in .DNG file and Lightroom default sharpening re-applied
Steps to reproduce issue:
  1. Open Fuji RAW file in Lightroom Classic, and remove default [Details] settings.
  2. Open Photo AI via Plug-in, apply denoise and sharpening, save back as .DNG to Lightroom Classic
  3. Open .DNG in Lightroom Classic. The camera-specific colour profiles (eg Astia Soft) are not visible, just the Adobe colour profiles. Also, the default Lightroom [Details] are applied, ie Sharpening Amount = 40, Radius = 0.8, Detail = 60 etc, even though Sharpening was done in Photo AI
I have repeated the above using DXO RAW 2 from the same starting point and both issues above are not present, so it proves that there is an issue with the .DNG file created by Photo AI.
Topaz Photo AI [v2.0.5] on Windows V.11, Lightroom Classic Release 13
