Nikon Z8 not supported by Topaz Photo AI
Apparently Photo AI does not yet support images from the new Nikon Z8. How soon will this be addressed?
Yeah having the same issue when using topaz on its own and when opening from file → plugin extras from lightroom classic. Works fine using Edit In menu from lightroom. Guess that’s because it converts the image to a different format.
The Z8 is not supported yet by the RAW library we use so we will need to wait on the LibRaw team for this, please see the list below for supported cameras;
https://www.libraw.org/supported-cameras
After doing further testing, it seems to be the Raw recording type selected in the Raw recording menu in the camera. Loseless compression seems to work fine while the two High efficiency options do not.
Thanks.
My Z8 is set to Raw, lossless compressed. When I open an image in Topaz Photo AI with >File>Plug In Extras the image goes through Processing and I can see the improved image but when I Save I get this message: “Image failed to process. Processed photo may be from an unsupported camera or malformatted file:
/Volumes/TJ1 Samsung/Pictures/LR Imports/NZ8_0138-2.dng
canReadFile: dng_error_unsupported_raw
When I open the Support button I get a list of cameras supported and those not supported which includes the Z9 but the Z8 is not listed.
However, I also have a Z9 and those images are processed perfectly and saved by Photo AI.
When I use the >Photo>Edit In route with a Z8 image it processes but saves as a .tif file.
Hopefully the Z8 will be part of an upgrade soon.
Surprised it hasn’t yet happened since Photo AI seems to update very regularly.
Tom Jones
M: 1-602-799-4000
tomjones33@cox.net
The information contained in this electronic mail message is confidential information intended only for the use of the individual or entity named above, and may be privileged. If the reader of this message is not the intended recipient or the employee or agent responsible to deliver it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please immediately notify me by telephone (602-799-4000), and delete the original message. Thank you.
We’re working on supporting the Z8 in a future release coming soon, likely next quarter.
There’s a significant amount of testing that goes into adding a new camera model but it’s a high priority for us.
Thanks.
Tom Jones
M: 1-602-799-4000
tomjones33@cox.net
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
When you bring in a Nikon Raw High Effeciiency file all that shows on the screen is coloured lines.
This is for Nikon Z8
It is unacceptable that Topaz does not support all of Nikon’s compressed files. While I understand there are work arounds, however, it collides with my workflow.
Please focus on this problem.
Many thanks
Regards,
Ed
As this is a user to user forum you probably won’t get and answer but, support for Nikon’s High Efficiency compression (Z9 camera support) is currently in beta testing.
If you want an answer from Topaz raise a support request at the main website.
I would use NEF raw with no compression in the interim.
The latest update for Topaz Photo AI, v1.4.0 has support for the Z8 and Z9 HE* file types.
Please update your Topaz Photo AI and then you will be able to use the files.
You can update by opening Topaz Photo AI and clicking the Update Available button on the top right or downloading a new installer from the downloads page:
https://topazlabs.com/downloads/
I cannot process NEF files from my Nikon Z8 using the Files> Plugin Extras> pathway, I get an unsupported file message when it comes to save the image. I can use the ‘Edit in’ which processes to TIF but comes with the advice that I get better results s if I go the Files route. Am I missing something or is an upgrade coming?
I believe that the HE/HE* Nikon pseudo-RAW formats are not supported but the NEF will be supported by LibRAW as soon as possible. If you raise a support request at the main website for Topaz Labs they will be able to help.
Hi @moliverzw,
The Z8 is not supported yet by the RAW library we use, please see the list below for supported cameras;
Thanks for the list of cameras, Preston. Having just bought the Z8 I will not be selling it to buy a camera from the list :wink:
Not only is it not supporting the Z8 but with the Sigma Lens that has been supported for almost a year and a half of my usage has dropped off the list. You got lots of work to do Topaz!
Au secours, impossible d’ouvrir les images provenant du Z8, alors que la version prĂ©cĂ©dente le permettait. Je ne peux pas travailler mes images de mariage. Vite s’il vous plaĂźt, apportez un correctif.
Merci.
AU SECOURS IDEM, depuis la derniĂšre mise àç jour chargĂ©e plusieurs fois, plus aucune image ne s’ouvre. En bas gauche : inscription NO FILTERS ENABLED.
J’ai tout tentĂ©, rien Ă  faire.
Bonjour,
J’ai une alternative. Passer la photo sous Photoshop, la rĂ©enregistrer sur le disque dur. Puis l’ouvrir dans Topaz. LĂ  ça fonctionne.
Il y a peut-ĂȘtre eu un conflit avec les autorisations systĂšme. Veuillez dĂ©sactiver l’antivirus, le pare-feu, le VPN ou le proxy pouvant se trouver sur votre ordinateur. Ceux-ci sont connus pour empĂȘcher le programme d’installation de tĂ©lĂ©charger les fichiers de modĂšle. Relancez ensuite le programme d’installation. Vous pouvez tĂ©lĂ©charger un nouveau programme d’installation directement Ă  partir de la page de tĂ©lĂ©chargement. Download
