Is Topaz AI the replacement for Topaz Remask?
I have the trial version of Remask 5. Is there a way to save an image for further work on the image? Thank you kindly.
I assume you mean Mask AI which is the next masking application. You can save the Tri-mask as a file and open it again to keep working on it.
ReMask is no longer sold and is classified as a legacy product therefore there is no support.
