Need help installing Topaz PhotoAI 1.3 as a plugin in Affinity Photo2.
Both installs went fine (Mac mini M2 Pro 16/512 booted from external T7 SSD), but no plugins were found in Affinity Photo preferences panel.
I have no terminal skills, so I mucked about copying files between various plugin folders that I accessed via
“Show package contents” on the app files in the Applications folder. Finally the plugin showed up in AP2 and opened PhotoAI- but now PhotoAI won’t save a file until I BUY MORE SEATS!
Went back and deleted all the files I had copied. Took a while but I guess I got them all. PhotoAI works again, but no plugins in AP2.
Is there a simple way to make this work without setting off alarms or bricking my computer?
Which files do I need to move or copy, and from where to where?
