Need help converting audio stream
I’m trying to import a .wmv file, but I get this error message:
Error: Audio stream #1 contains ‘wmav2’ audio which can’t be used with the ‘.mkv’ container.
Select an alternate Container to copy audio, or change Audio Mode to ‘Convert’ (this may cause a loss in audio quality).
I don’t know where to find the audio controls since I am new and learning the program. If anyone can steer me in the right direction that would be great.
Thank you! It was a bit small and I didn’t even see it.
