Hi,
Don’t seem to be able to export despite multiple tries! Seems to go through the full processing BUT then when the process ends and the final write routine should end the following is shown at the bottom of the log. Although I haven’t checked every log the process ends the same so presume that it is general.
Any help appreciated.
LAST ENTRIES IN LOG FILE:
"2023-10-22 11-16-08.124 Thread: 952 Info OUT: 6 frame= 1797 fps= 31.4226
2023-10-22 11-16-08.193 Thread: 952 Info OUT: 6
2023-10-22 11:16:08 24944 INFO: Stream has ended 00000267A2F69030
2023-10-22 11-16-08.215 Thread: 952 Info OUT: 6
2023-10-22 11:16:08 19776 INFO: Exporting transforms to file: C:/Users/xxs/AppData/Local/Temp/84139202/temp/tvai_955560158_cpe.json
2023-10-22 11:16:08 19776 CRITICAL: Write error! Unable to write the CPE file to C:/Users/xxs/AppData/Local/Temp/84139202/temp/tvai_955560158_cpe.json Size: 1800x4:1:STABERROR: Unable to write the CPE file. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<^^^^^^^^
2023-10-22 11-16-08.297 Thread: 952 Info EXITED: 6 11 0
2023-10-22 11-16-08.297 Thread: 952 Info Going to delete path: “C:/Users/xxs/Videos/LionsvsBuffaloKruger - Made with Clipchamp_1_stabvv_temp.mp4”
2023-10-22 11-16-08.297 Thread: 952 Info Close and delete path “C:/Users/xxs/Videos/LionsvsBuffaloKruger - Made with Clipchamp_1_stabvv_temp.mp4”
2023-10-22 11-16-08.297 Thread: 952 Info Going to delete path: “C:/Users/xxs/Videos/LionsvsBuffaloKruger - Made with Clipchamp_1_stabvv.mp4”
2023-10-22 11-16-08.297 Thread: 952 Info Close and delete path “C:/Users/xxs/Videos/LionsvsBuffaloKruger - Made with Clipchamp_1_stabvv.mp4”
2023-10-22 11-16-08.310 Thread: 952 Info ~TProcess(): destroyed
2023-10-22 11-16-26.121 Thread: 952 Info Logging files: 10
2023-10-22 11-16-26.765 Thread: 952 Warning Showing in graphical shell: “C:\Users\xxs\AppData\Roaming\Topaz Labs LLC\Topaz Video AI\logs\logsForSupport.zip”
2023-10-22 11-27-41.199 Thread: 952 Info Logging files: 10
2023-10-22 11-27-41.862 Thread: 952 Warning Showing in graphical shell: “C:\Users\xxs\AppData\Roaming\Topaz Labs LLC\Topaz Video AI\logs\logsForSupport.zip”
2023-10-22 11-34-41.903 Thread: 952 Info Opening current log C:/Users/xxs/AppData/Roaming/Topaz Labs LLC/Topaz Video AI/logs/2023-10-22-10-31-54-Main.tzlog"
Topaz Video AI [v4.0] on [Window/]
