Multiple issues that keep carrying over
Firstly,
The installer… For a few months now, when the installer finishes and asks if you’d like to launch the program, it launches the program if you don’t select the box to launch.
If you select “launch program now” it launches two instances.
Second “new” issue (which has been something that was an “issue” before)
Scaling to a percentage, you need to use full numbers again, and cannot use something like “112.5%” … I’m not sure which version this started to become a thing again, but it has been persistent for quite a while now with the betas.
“Second Enhancement” – In this setting, if you try to use Gaia or Artemis, you cannot select which gaia or artemis model you want to use. It’s just a generic setting. The other models seem to have all their options intact.
…more to come, I need to keep better track on these, but hope these three can be easily fixed in the next release since they are fairly trivial (but potentially substantial in use-cases)
Will report back when i get to some of the other small things i’ve been noticing lately.
Thanks.
