Motion Deblur - Aliasing
Hello,
I am experimenting with upscaling a 1080p video to 4k using Proteus fine tune, manual settings. Further, I am using the motion deblur model Themis. It works very well aside from the fact that I seem to get aliasing artifacts in high detail areas like hair or detailed texture patterns. Is there a step I can take to minimize this? It seems to happen no matter the Proteus settings used. Let me know if you need screenshots.
Thanks
Edit: It would also help to know in what order the model stack is executed in.
instead of using the Themis deblur , use Proteus Relative Auto and set the deblure to 80. that would give you almost the same sharpening effect as Themis but with less artifacts.
@Akila 's advice is great and if you are still having issues, please let me know :slight_smile:
Here is an article for the order in which filters are being applied.
Great, thanks for the help everyone. Will give that a try and see how it works.
