i’m in a restoration environment, i work on a sequence did from different clip, every clip can be enhanced with more models, for example i had an old dv sequence where i had lateral plant that work fine with proteus, central door with artemis low, motion clip of actor in front of camera with artemis strong dehalo.
I need to load more time the clip and setup every single output, then later in a composite software i will do mask and compose the best of picture from every clip.
my request is ability to do a render queue instead to load more time clip, is simplier and clear.
an alternative way to do many render from veia
