More info in Export window
Dear Topaz, please consider expanding the information in the Export window. In the “Properties” column, apart from the word "Enhancement”, it would be good to see what models were used. The file name could easily take up two lines, because now with long names I can’t even see half of the name.
If you click on the file name it should show you more of it now. Are you seeing that, or is part of the file name still obscured?
Requests have been made to re-evaluate the export queue window to provide more clarity for users and this is being looked into.
I had no reason to believe that I could click to find out the entire filename. This should be more transparent. And as I see, once the processing is finished, this click trick no longer works.
More transparency on this element would definitely be appreciated.
And by the way, it would be good to improve the element of predicting the end of processing, because for SLP it does not work at all.
