More extreme noise reduction
I have an image with a noise pattern, but it is seemingly not recognised by Photos AI, I would assume as the noise pattern is too large. It seems counter-intuitive to make the image smaller to be able to target the noise.
Could a model targeting larger noise be made available? As a stretch goal it would be nice if there were some guidance provided on ideal sizes for things (noise, faces, foliage etc).
  1. The original image file.
  2. The processed image.
Dropbox File Request
