More choices for Save to location
Could we have more options for the Save to locations for images? It’d be great if TPAI could remember, say, the last ten locations as a choice in a drop-down menu. At least, more than the current limit.
If you work on several different projects at any time as I do, it’s a bore to keep navigating to a folder you used just recently.
Also, as part of the automatic/default options, I would like a sticky subfolder of the original whether this defaults to something like output or can be edited.
@tom.ang Thanks for sharing your idea!
When you go to the Save To location, you can select “Browse” and find a specific subfolder on your computer.
Was your suggestion to have these options directly in the drop-down menu?
