Model not found: iris-2- Failed to configure output pad on Parsed_tvai_up_0 - Corrupted zip?
[Parsed_tvai_up_0 @ 000002575568ADC0] Model not found: iris-2
[Parsed_tvai_up_0 @ 000002575568ADC0] Failed to configure output pad on Parsed_tvai_up_0
Error reinitializing filters!
Failed to inject frame into filter network: Invalid argument
Error while processing the decoded data for stream #0:0
Conversion failed!
2. Your system profile
Win 10
Executed the ffmpeg command manually
ffmpeg “-hide_banner” “-t” “2.0416666666666665” “-i” “D:/Dress.mp4” “-flush_packets” “1” “-sws_flags” “spline+accurate_rnd+full_chroma_int” “-color_trc” “2” “-colorspace” “2” “-color_primaries” “2” “-filter_complex” “tvai_up=model=iris-2:scale=0:w=852:h=480:preblur=0:noise=0:details=0:halo=0:blur=0:compression=0:estimate=20:blend=0.2:device=0:vram=1:instances=0,split=2[out1][out2]” “-map” “[out1]” “-c:v” “h264_nvenc” “-profile:v” “high” “-pix_fmt” “yuv420p” “-preset” “p7” “-tune” “hq” “-rc” “constqp” “-qp” “18” “-rc-lookahead” “20” “-spatial_aq” “1” “-aq-strength” “15” “-b:v” “0” “-an” “-map_metadata” “0” “-map_metadata:s:v” “0:s:v” “-movflags” “use_metadata_tags+write_colr” “-metadata” “videoai=Deinterlaced and enhanced using iris-2and recover original detail at 20” “D:\TempTopazAI/395684719/previews/Dress_iris2.mov” “-map” “[out2]” “-c:v” “tiff” “D:\TempTopazAI/395684719/temp/_tvai_9442730/%06d.tiff”
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘D:/Dress.mp4’
Model should be there
Thank you for your help
The file was there, nevertheless it seems that Topaz is downloading it again.
2023-09-22
2023-09-22 15-23-17.331 Thread: 4848 Info OUT: 2 15:23:17 6
2023-09-22 15-23-17.331 Thread: 4848 Info OUT: 2 088 CRITICAL: Cannot open zip file at: D:\TopazAI\nyx-v1-fgnet-fp16-1088x1024-1x-rt705-8500.tz
2023-09-22 15-23-17.332 Thread: 4848 Info OUT: 2
2023-09-22 15
2023-09-22 15-23-17.332 Thread: 4848 Info OUT: 2 :23:1
2023-09-22 15-23-17.332 Thread: 4848 Info OUT: 2 7 6088 INFO: Proxy Settings: 0
2023-09-22 15-23-17.332 Thread: 4848 Info OUT: 2 hostname: port: 0 username: JSON: {“enabled”:false
2023-09-22 15-23-17.332 Thread: 4848 Info OUT: 2 }
2023-09-22 15-23-17.333 Thread: 4848 Info OUT: 2
:AIINFO: Downloading Model nyx-v1-fgnet-fp16-1088x1024-1x-rt705-8500.tz
2023-09-22 15-23-21.260 Thread: 4848 Info OUT: 2
2023-09-22 15:23:21
2023-09-22 15-23-21.260 Thread: 4848 Info OUT: 2 6088 INFO: RESULT for https://veai-models.topazlabs.com/nyx-v1-fgnet-fp16-1088x1024-1x-rt705-8500.tz is 200
2023-09-22 15-23-21.616 Thread: 4848 Info OUT: 2
2023-09-22 15:23:21 6088 INFO: Compressed Buffer for nyx-v1-fgnet-fp16-1088x1024-1x-rt705-8500.tz verified
2023-09-22 15-23-21.618 Thread: 4848 Info OUT: 2
I think the problem might be a remote corrupted file.
Hello,
Could you send us a note at help@topazlabs.com with the full log files from the app?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport.tar.gz” file to your reply.
Did you ever figure it out?
Yes, this models are downloaded from M$ Azure. I blocked some of those domains as they are part of their tracking apparatus. Once I found the proper rule, I unblocked the downloading and it worked.
could you point to the exact addresses? Cause I probably have the same rules in place
