I ran out of space on my HDD and while cleaning it I noticed Topaz makes huge model files, some of them 2Gb. In principle that’s fine but they are not removed when I exit the program. The consequence is that the files keep on accumulating? Is there a way to make a clean exit and delete them automatically?
THX
Przemko
The model files used by Photo AI are downloaded locally for processing tasks. These files are necessary for the AI algorithms to work efficiently on your machine, and they are not meant to be constantly re-downloaded. However, they remain on your system after processing to avoid the need for repeated downloads.
Currently, the model files are not automatically deleted when you exit the program. To manage the storage, you would need to manually delete these files.
Thank you
It would be nice to have an option then at the exit “delete yes/no”. They are huge and probably not everyone is even aware of that
Kind regards
Przemko
