Unable to fully download topaz gigapixel ai generative models because of a critically unstable network speed
the installer fails to repair those files due to an unstable network issue.
downloading the model in the app is taking too long and constantly failing
if you’re able to share {rxl_unet0-v2-fp16 and
rxl_unet1-v2-fp16} models, I’ll be able to download them separately and import them into the model file afterwards
i was able to download those models later at night time, when the internet bandwidth goes higher
This issue may occur if the internet drops or security settings interfere with the AI model installation for Gigapixel.
Follow these steps to resolve:
- In Gigapixel, go to Preferences > Settings > General
- Toggle “Enable in-app model downloads” to the right to turn ON
- Close and re-launch Gigapixel
Depending on the connection strength, you may need to repeat these steps.
Hardwiring your connection for consistency could help, too.
Check if a VPN, proxy, firewall, or anti-virus software is blocking the connection.
Temporarily disable these and add our sites, topazlabs.com , and topaz-labs.net, to your safe lists.
