Every time I move a photo from lightroom to topaz, after the new updates, it takes forever to download models again! Help
Steps to reproduce issue:
Photo AI should integrate automatically. However, if it didn’t, please be sure Photoshop and Lightroom are closed and then reinstall Photo AI.
If the auto integration does not work, then you may need to use the manual steps below. This shows Sharpen AI as an example, and the other apps will follow the same steps: Sharpen AI Photoshop Plug In Integration
If you still have any conflicts, please send back some screenshots of what you see.
