hello. can i get information about this error? what do i need to do to fix it?
I have the same pop up
I am getting the same error.
Da oggi 26-11-2024 ho lo stesso problema.
same issue ;-(
Risposta ricevuta dal Supporto Topaz:
Missing models means that a security program on your computer blocked some of the AI models from downloading.
Here are the steps to download the missing models.
NOTE : Because the models were previously blocked from downloading, it’s very important to momentarily turn off any security software you have before re-installing. This can be VPN, proxy, firewall, anti-virus software or Windows Defender. You may need to test rerunning the installer below with a mobile hotspot, to rule out the router being the issue.
Once all security features turned off, rerun a fresh installer: Gigapixel 8.0.2
2.IMPORTANT: Do not perform any uninstallation; only rerun this installer and it will download the missing models only.* -
Once done, please retry opening th app to see if you have all the models installed.
Ho seguito le istruzioni ed ora e’ tutto ok.
