One of the many doorways and walkways in the Mission. I’m looking for a diagonal line.
Here’s original:
Here’s the result using TS2 from within P.E. 15
Here’s original:
Diagonals often make the picture much better. Your picture has a few diagonals in it but your processing hasn’t helped. To demonstrate, I applied some tone mapping, saturation increase, cropping and sharpening (Sharpen AI) to enhance the framing and the diagonals that are there. Also, adding a blue gradient to the sky gives a better look for the sunny day.
Yes, definitely a big improvement over what I did to it.
I like the capture a lot. There are a lot of interesting ways of looking at the image and I like what you both did
Very nice !
Nice image, Harry! I like the processing, too but would lower the opacity of the effect a little bit
Thanks Ken.
Thank you Pierre.
I’ll try that Peter. Thank you.
