Missing recall settings
Hi, using Topaz for a while. I use the same settings to all photos, so it would be nice to have personal settings buttons.
Thanks for your insights, I can see how having presets is useful if you make the same edits. In the meantime, if you import all the images in one batch, you can go to Edit > Apply Current Settings to All to transfer all your edits from one photo across the batch.
Thanks. Since is too slow to batch process 300 photos, I would love to preset ande just hit go… I am using the feature you refer though.
That makes sense. I appreciate it!
