Missing Autopilot panel
I just purchased Topas Photo AI - I don’t see the autopilot panel or the option to fix Lens or motion bur.
Just have a quick look into the preferences in the pull down menu on the top! :slight_smile:
Thank you. Is it possible to have it saved to the side panel or do you need to go into preferences each time?
I think you must configure the autopilot in the preferences and save the settings right there!
If you are talking about processing options, make sure you know the application and you can find the user guides here:
It will also explain how to set the autopilot options as you want them.
You can access Lens and Motion blur by clicking into the Sharpen filter. All these settings can be configured in the Preferences > Autopilot menu.
