Version 7.1.3
There is a small UX bug in the preset, I can not see the options.
- Go to Preset
- Custom
- Click the 3 dots for settings
- The 2 options are shown but behind the windows, You can only read the options:
e preset
preset
See image:
Regards
Constant
The UI team is aware of this issue and working on getting it resolved in a future update. Thank you for sharing that you are seeing it as well.
But what are the 2 options?
Apologies for the delayed response.
The top one is Rename Preset and the bottom one is Delete Preset.
system
(system)
Closed
6
