Masking not working
topaz masking not working with my Mac m1,brush size slow to respond and then freezing when adding or removing mask, this was working ok until last upgrade
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Topaz Labs Download Page
tried this John but it didn’t work, I will wait for next update as many users with Mac m1 are having problems
