I just installed Topaz Adjust AI which I received as a free upgrade (thanks, Topaz!)
I tried using it as a standalone on several images and immediately looked for a masking option. Is there one?
No it isn’t there yet but I believe it is in the works. In the meantime you could use it as a plugin and mask out the effect using layers.
Thanks Don that’s what I thought. It’s not a problem because I seldom use such plugins as standalones.
Am I just missing it? Is it possible to use a mask in AI Adjust so that just a part of an image is “adjusted”?
Not at this moment without using a host and layers. I have moved this to Product Feature Requests.
